Techwood 32" & 37" TVs from Woolworths
liam 360
After almost settling on the Woolworths 32" technosonic (many thanks to the vast advice on here) i come accross this one also from woolies;
Woolworths 37" Techwood
# 37" LCD Screen
# HDMI Input
# HD Ready
# NICAM Stereo
# 2 x Scart Sockets
# 1000 Page Text
# Headphone socket
# A/V Connections
# NTSC Playback
# Auto set-up
# Remote Control
# Instruction book
does anyone know anything about this lcd? google had no trace of it, i have searched the forums and found a thread from someone else but it had the wrong title so thought this lcd needed its own thread.
the size difference from 32 to 37 is pretty huge for only 25% more pricewise.
I shall be using the lcd for XBOX 360 and hopefully if it has vga as a pc screen, is 37" too big to use as a pc screen?
i will try to find more info on it tomorrow when i visit the Newcastle Woolies so stay tuned here for that.
Anyone?
SatDude
Hi, I think it’s now time to start a thread about this TV, the technosonic 32” thread is massive and we will see where are we going to get with this one, hopefully it will help as much people as the other thread did.
It helped me! I had 2 Technosonic and I’m going to try the Techwood now… So if anyone here has one please post your reviews and comments.
Techwood 32" TV
SatDude
I was told yesterday by someone at the Woolworths help line that this TV and the Technosonic have the same specs, and that the difference is that the menus are different with more options and that this set is more reliable. If it really is I don't really know but I will tell you guys as soon as I get my hands on one.
LV426
Administrator
Staff member
Merged a couple of similar threads.....
toycollector
# 37" LCD Screen
# HDMI Input
# HD Ready
# NICAM Stereo
# 2 x Scart Sockets
# 1000 Page Text
# Headphone socket
# A/V Connections
# NTSC Playback
# Auto set-up
# Remote Control
# Instruction book
Anyone?
Techwood made in TURKEY by Vestel.No idea of reliability.Does look very plasticky compared to the Thomson /Techno
liam 360
How about changing the title to "Techwood 32" and 37" TV from Woolworths"
Since the posts you merged were about different sets!
thanks
Ballistic
Went into 2 different Woolworths around Derby today and the 32" is now a Techwood, not Technosonic.
Both stores had 1 working display model (can't say I was that impressed)which they were taking orders from, couldn't confirm a delivery date.
D
dapier
I have just finished working at Currys after 8 years and can tell you that the stockrooms are bulging with faulty Techwood LCD TVs no parts are available so if you buy one and it breaks down after a reasonable period say 18 mths then unless you have an 'extended warranty' you will be left with a worthless pile of s***
# 37" LCD Screen
# HDMI Input
# HD Ready
# NICAM Stereo
# 2 x Scart Sockets
# 1000 Page Text
# Headphone socket
# A/V Connections
# NTSC Playback
# Auto set-up
# Remote Control
# Instruction book
Anyone?
marty2005
I've just ordered the 37" Techwood. Should get by 28th - If I'd ordered last night I could have had it by 27th.
liam 360
well please remember to come back here and post a review + pictures! damn choosing a tv is hard work, are you a 360 user marty?
B
brianl
just bought the 32 inch for £399. I think the fascia looks fairly smart. Free view from stb looks awful (as it does on most hd tvs). analogue receiver built in looks suprisingly good. Ill just use it as a monitor. Trying to feed it a signal with a dvi->hdmi cable from pc. works well and HD looks amazing! Problem is that i cant get picture to fill the screen. Any suggestions?
There is no VGA input.
marty2005
No VGA input? Are you 100% sure?
I might have to cancel my order as I planned to use the HDMI input for dvd recorder.
G
geeforce2006
:hiya: Picked up my 37" Techwood from Woolies on Thursday - bit of a bummer really as on Friday they reduced the online price by £100 to £499! -I've e-mailed them to try and get my money back.(The reduction is only untill the 26th of december though!) Im going to use mine for the Xbox 360, the 32" techwood has component input so I am asuming this one has aswell - I will open it on Christmas day and as soon as I've tested it I'll tell you all how it is! - Ill try and post some picks aswell!
marty2005
Can't you have a quick peek now?
What does it say on the box?
Billposter
Could you return the first one and order a second one at the reduced price ? Can you only return for any reason if it's bought online ?
A little bit of a hassle but for £100 I'm sure some would think it worthwhile.
Easier of course if they said will give you the first one at the lower price and issue a refund for £100. Of course if it's only cheaper if you order online then buying and collecting from the store puts you at a disadvantage if the store price is higher.
SatDude
Hi, after 2 technosonic I was told to exchange it and get the techwood, as this TV was better. I have it now and in my opinion the TV is rubbish, ok sd quality might e a tiny little bit better but between this TV and the techno I'll pick the techno, the techwood looks very cheap, no vga connection and I had it all sorted with the techno via dvi/hdmi and vga and this one I can't get it to work properly with dvi/hdmi. I don't like it, not easy to change between connections and the specs are defiantly not the same. I would say the techno is better!!!
BTW not sure if it was a great idea to merge this two threads…..
mastermax
Hi, after 2 technosonic I was told to exchange it and get the techwood, as this TV was better. I have it now and in my opinion the TV is rubbish, ok sd quality might e a tiny little bit better but between this TV and the techno I’ll pick the techno, the techwood looks very cheap, no vga connection and I had it all sorted with the techno via dvi/hdmi and vga and this one I can’t get it to work properly with dvi/hdmi. I don’t like it, not easy to change between connections and the specs are defiantly not the same. I would say the techno is better!!!
hi mate what specs do you think are different between techsnic and twoody ?
IF you liked the techno, why didn't you stick with it then??
weebroonieuk
hi mate i have the 37incher aswell just got a dvi to hdmi to rig it upto the media center
yes the remote is terrible and its painfully slow at changing inputs but this is more or less a temporary telly till the ps3 etc is out and it and the x360 work at 1080p and i will get a set that supports that ..
i only use the x360 and mce so changing inputs doesnt really happen alot for me so i can live with that...
what is driving me nutts is the dodgy resolution the tv is displaying from the pc
im gonna have to edit the ini file to get it at the exact resolution and hopefully that helps it ....
weebroonieuk
well i wont chuck it away or anything lol i keep buying the bargain sets and shuffling them round the house... kids are getting what was my bedroom telly, an acer 26 inch lcd to go with the media center ive built them for xmas
so ive got this 37incher at the foot of our bed... more imposing than i thought it would be and to think i was gunning for a 42incher.... :)
so sometime next year kids will get this one and il find somewhere for the 26 incher and buy a high end 37 for the bedroom as i think a 42 inch screen at the edge of the bed is just taking it too far!
good playing gears of war and pgr and fight night tho find myself ducking an diving more than i used too :p
weebroonieuk
a 32 inch acer lcd lol! got it last year but it doesnt really get used due to work etc its come home shower eat and fall back on the bed and play the kids at some racing or shooting games through the system link thing, my fav is call of duty i always find out where they respawn and headshot them till they throw a tantrum and stop playing :D , the house was getting rewired kitchen and bathroom etc so the place has been turned upside down and the bedrooms have basically been made into our living room for the moment anyways...
Im still struggling to get this monitor to set itself properly had a good go at it with powerstrip but still the same amount of outlining around the picture and the area that is displayed isnt very good atall....
G
geeforce2006
:hiya: Have spoken to woolworths about the fact that the price was reduced by £100 but they have said that they wont refund the difference (Amazons policy is far better - if the price is lowered within 28 days they refund you the difference) - anyway for anyone who payed the higher price the best thing to do is order the T.V again and then return it on the other reciept (as reccomended by Woolworths customer servces!) - cant see the logic in it myself but will do it to get some money back. The only new downside is that there is no collect at store option so you have to pay £25 for delivery - its still worth it for £75 back though! - As far as info on the box is concerned though, it's as sparce as woolworths own website - not much info at all. If this TV turns out to be rubbish though the Evesham one on their website looks food for £479 even if it is 32" - it comes with a 2 year swap out warranty aswell!
SatDude
Because i had a faulty set mate, and to have a good one for christmas i got it axchanged for the techwood but is going back for another techno!
Latest News
Sonus faber unveils new flagship Arena speaker series
  • By Ian Collen
  • Published
Sharp showcases its upcoming 4K TV and audio line-up
  • By Ian Collen
  • Published
HiFi Rose announces all-in-one RS520 audio streamer
  • By Ian Collen
  • Published
LG Display set to launch its own 27 and 32-inch OLED panels in 2023?
  • By Ian Collen
  • Published
What's new on Netflix (UK) for October 2022
  • By Ian Collen
  • Published
