Technosonic SX-009 Multi-Function Wireless Headphones Aren't Loud Enough
Discussion in 'Headphones, Earphones & Portable Music' started by nickclone, Dec 25, 2006.
  1. nickclone
    nickclone
    I have them plugged into my computer with the headphones volume all the way up, WMP volume all the way up and the master volume maxed out and its still not loud enough. Is there a way I can make them louder.
  2. DorKnight
    DorKnight
    Oct 11, 2005
    329
    +35
    What soundcard do you have and which connection are they currently connected to?
  3. nickclone
    nickclone
    Nevermind I figured it out, I did something stupid.
