ABARKIE,
You welcome to buy my water Leak stopper,
Vu+duo stands for me as bellow
1-V= Very
2-U=unreliable
3-D=disaster
4-U-Un wanted
5-O-Obsolite,
You really better off to buy tmsingle or tm2t , if you still want to buy this obsolete Brocken box,
No water damage yet but 2 tuners are not working also when it was working I had to turn off from mains at least every 2 days otherwise memory leak took over,
This piece of junk cost me £349 about march last year inc, delivery you can buy it at £150 delivered to you in uk with 100% Big NO guarantee except 2 tuner all other parts working,
I learnt my lesson not to buy anything unless is uk supplier based with long record of stability that can give service if dealer goes bust, bought my tmtwin direct by mail from Technomate Edmonton London,
It has been few days since ,working very good no problem also has been on standby if I do not use it I have never turn it off from power yet
Been as good as gold installing my 3.5 inch hard disk internal with sata cable never missed any epg program recording which regularly was turned off by vu because of re booting
Which was after effect of memory leak ,picture quality is better also faster in All menu navigations with extra 3Gbit memory which is 372MB helps a lot to run plagins, streaming,
daily use also using bbc itv I player and 1-channel been running without any problem.
Now kids can watch different channel in their room with their pc using webif while leaving me alone.
Since last few days nothing to report except has been very good if any problem I will post it,
