Technika TKSB213 and LG 55LM670T
Discussion in 'Soundbars, Soundplates & Soundbases' started by zeddy, Feb 21, 2014.
  1. zeddy
    zeddy
    Aug 25, 2010
    103
    16
    Hi All,
    You're probably thinking that the above is not an ideal pairing, but I'm saving up for an AV receiver and a good speaker package, hence why I've gone for a budget sound bar (the lowest of the budget sound bars :suicide:). The sound bar will be mainly used for playing music via Bluetooth but also when watching movies or football, as the sound from the TV is a little poor in my living room (14ft x 17ft).
    The first thing I want to know is, would the sound bar work with my TV? I know the TV has digital out, but the sound bar only has AUX and COAXIAL, so would it work? And if it would work, what cable would I need to get it to work?
    Thanks everyone
  2. zeddy
    zeddy
    Aug 25, 2010
    103
    16
    Anyone?
  3. spyder viewer
    spyder viewer
    Dec 18, 2007
    5,846
    2
    Kent, UK
    +1,285
    Having read the reviews on the Tesco website, I'm surprised you are thinking of wasting your money. Who knows what the aux input is , it might be a 2.5mm jack so should take headphone output from tv. Are you sure you can't adjust the sound settings of the tv to give better short term improvements?
  4. zeddy
    zeddy
    Aug 25, 2010
    103
    16
    The sound is quite bad on the TV when watching movies so I definitely need sound bar and I don't mind taking a punt at £30.00 to be honest.
  5. zeddy
    zeddy
    Aug 25, 2010
    103
    16
    I bought it and it has the folliwing inputs as shown in the picture below. What cable would I need to get it to work with the LG LM670T?
  6. zeddy
    zeddy
    Aug 25, 2010
    103
    16
  7. sosen13
    sosen13
    Feb 24, 2014
    979
    46
    Peterborough, United Kingdom
    +102
    technika.. ?! nooo!
