Technika Smart TV 22-212i Sky remote code needed
Discussion in 'Sky Digital TV Forum' started by Hamgray, Feb 20, 2014.
  1. Hamgray
    Hamgray
    Jun 11, 2012
    Hi Guys,
    Recently got a second hand Technika Smart TV, came as just a TV - no remote or WiFi dongle.
    Bought remote for £25 (has a qwerty keyboard on the back -WOW!)
    Using at present a Sky black Wireless box (available on eBay) after finding the address to get into the settings (can be provided if needed) - may have even found it on this site?? Can't remember.
    What I need next to complete the set-up is the code for my Sky remote to work the volume.
    Can't find one anywhere - has anybody got one?
  2. JayCee
    JayCee
    Jan 20, 2004
    23,769
    Lanarkshire
    +2,572
    Have you checked on the Sky "Interactive", "Sky Customer services", "Program my remote control" menu?
    Bear in mind you may need a revision 8 or 9 remote as any earlier remote is unlikely to work.
    Try all codes listed for Technika.
  3. Hamgray
    Hamgray
    Jun 11, 2012
    Yes thanks, tried that. For a start Technika (a Tesco brand) is not listed as a TV brand, but when I type it in says: "We have a code for your model but you need a newer Sky remote version". I'm using v9 and didn't know there was a later one?? Is there a v10 out now?
  4. JayCee
    JayCee
    Jan 20, 2004
    23,769
    Lanarkshire
    +2,572
    Yes, I've long been aware of that.
    It is..it was there today when I checked, for a REV9 try 2134 or 2196
  5. Hamgray
    Hamgray
    Jun 11, 2012
  6. JayCee
    JayCee
    Jan 20, 2004
    23,769
    Lanarkshire
    +2,572
    I'm using the interactive button on the Sky remote to access the menu as I stated above...even using the link you gave, there are a few codes listed if you select V9 for the remote, enter the make but leave the model field blank.
