Technika LCDDVD19-918 Multi region hack needed
Griffy1973
HI,
Just wandering if there is a multi region hack for the TV/DVD combi Technika LCDDVD19-918.I recently bought it from Tescos.
Kind Regards
Paul
T
tommo2k
Make sure there is no DVD in player, turn over to DVD on input
PRESS
9
7
3
5
YOU WILL NOW HAVE A NEW MENU
SELECT REGION 0
Stan 24v
Just a quick bump for those who may have a cheapo Tesco tv, like me, that this works a treat! ;)
Thanks Tommo!!!
smiler
Yep works well on our 19" combo, thanks. :smashin:
Smiler
Jaunty
still working on recent Technika from Tescos :smashin:
Jaunty
Press the DVD input button on the remote
v8vee
Just tried this hack on the HDMISS10 which i bought today from Tesco's and does not work. Sorry!
bunters
I am trying to unlock the regions on a Tesco own brand 22" LCD/DVD TV, I have tried the 9735 code but it won't work.....anybody got any other ideas?
rikh
ANYONE KNOW A WAY OF DOING A TECHNIKA FAW08 PLEASE
Please ensure the TV source is set to DVD. (To set the TV source to DVD, press Source or AV on the remote control and scroll to DVD, then press OK.)
Make sure you have not loaded a DVD/CD into the TV, if a disc is loaded then eject the DVD.
When you see ‘No Disc’ displayed at the top left hand corner of the TV screen, press D.SETUP or DVD SETUP (on mine bottom left above GOTO button) on the remote control,
then press 1 3 8 9. A new menu screen will appear, now you will need to set the Region to 0. There are three ways to do this, please see below.
1) Scroll to Region, press the ‘right arrow’ and select Region 0 and then press ‘OK’ on the remote control. Turn the TV off and then back on again, using the remote control.
2) Press the down arrow on the remote until Region 0 is displayed at the bottom of the page. Turn the TV off and then back on again, using the remote control.
3) Press ‘0’ on the remote to display Region 0 at the bottom of the page. Turn the TV off and then back on again, using the remote control.
rikh
When you see ‘No Disc’ displayed at the top left hand corner of the TV screen, press D.SETUP or DVD SETUP (mine is above bottom left button that says GOTO) on the remote control,
TRIGGERLUFC
tried that but when i put code in no other menu screen comes up
marianne8
Thanks for this hack, it worked on my Technika TV/DVD combo :)
zoedarlin
hey! i tried the 9735 trick and it didnt work on my tesco technika 22e21w-fhd/dvd but i did select dvd set up button (bottom left, 2nd from bottom button) then selected the 4th option on the top of the menu titled 'preference page' and under 'TV type' i changed it from PAL to MULTI and now it works a treat!
Latest News
McIntosh launches C22 Mk V preamp and MC1502 power amplifier
  • By Andy Bassett
  • Published
Marantz unveils 12 Series Special Edition models
  • By Andy Bassett
  • Published
Samsung Galaxy Note 20 smart phone models launched
  • By Andy Bassett
  • Published
Toshiba launches UK4B 4K Alexa enabled TV
  • By Andy Bassett
  • Published
Mulan to premiere on Disney+ on 4th September
  • By Andy Bassett
  • Published
