Technika DVDFAW08 Region Code
ken441959
Has anyone successfully converted a Technica DVDFAW08 to play multi region disks. I can see a lot of suggestions as to what needs to be done, but no-one has stated that they have been successful. I am thinking of getting one of these but I would prefer if I could be sure they are able to be converted.
Many thanks in advance
flordiaregular
:clap:
  • Press SETUP
  • Cursor > 3 times to go to the "Preferences Page"
  • Press the NUM key and it will show on the screen (THIS IS THE PART THAT HAS BEEN MISSING FROM OTHER POST'S ALL OVER THE NET.)
  • Insert code 9653 with the remote control. The regional code appears on the screen.
  • Select the regional code: 0 = code-free; 1 = USA, etc
  • Press Play/Enter and then SETUP to get out
  • Done
i'm so proud of myself for finally sussing this and the kids are over the moon
That should sort you all out!!
Misterfin
flordiaregular says:
I can't see a NUM key on the remote. Could you please clarify?
Thanks.
