Technika DVD103 Remote Hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by darren_eaf, Oct 20, 2005.
  1. darren_eaf
    darren_eaf
    Oct 9, 2005
    559
    +30
    I bought a Technika DVD103 from Tesco and can not find a hack for it. Do any of you kind people happen to have one please?
    Thanks very much.
  2. kaydee
    kaydee
    :thumbsup:
    Here is a hack for the Technika 103 that should work!!
    Turn machine (and TV !) on
    Open tray
    type 9 7 3 6
    screen should then show Region 2
    Type 0
    Screen should then show Region 0
    Wait for display to disappear
    away you go!! - Good Luck.
  3. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,569
    The Shaolin Temple
    +43
    Yep the code works cant believe I got this player for £3.60 from Tesco. Price mistake?? (Thats with a 10% discount my wife works for them) and sorry there are none left!!
  4. doogie
    doogie
    Sep 5, 2004
    114
    +7
    wooo, thanks! The little un got one of these players for christmas and I couldn't find a hack for it anywhere.
  5. darren_eaf
    darren_eaf
    Oct 9, 2005
    559
    +30
    Thank you for the hack. I had resigned back to using my old LG, but now i can use the component form this one. Thanks again. :smashin:
  6. weebobt23282
    weebobt23282
    hello there just wondered if anyone knows of a hack so this player can play vcds
  7. weebobt23282
    weebobt23282
    hello again just found this and it WORKS!!
    Turn Tv and machine on
    Open Tray
    type 9 7 3 6
    screen should show Region 2 (or Region 0, since u have done the trick)
    type 7
    screen should show 'VCD Support ON'
    wait for screen to clear
    ..... that's all!
    Now you can play VCD without any problems!!
  8. Mr Sparkle
    Mr Sparkle
    Oct 17, 2003
    212
    OK, found the hack (as above).
    Does anyone know if this machine will play DVD+R ?
    And does it genuinely support Progressive Scan via the component output ?
    TIA
    Mr Sparkle
  9. kaydee
    kaydee
  10. Jo Purple
    Jo Purple
    HI all,
    I purchased this dvd whilst on holiday in the UK and it has served me well - all of a sudden it allows sound via the TV but no picture either via the dvd disc or if you turn it on the screen remains black - before it was the blue tecknika logo. Husband cannot find manual and not sure if the kids were messing around with the remote and some how lost the picture - can anyone help me get the picture back on!
    thanks:lease:
  11. darkcloud2011
    darkcloud2011
    Mar 31, 2009
    2,585
    83
    +200
    well worth it got this player for a fiver from tescos and was even given a few pence change lol. well worth it for a second bedroom works like a dream
