Quantcast
Technika BRSS10 Region-free Blu-ray/DVD Player - £40.94 from Tesco Direct
quicksand
Similar player to the Limit/Tevion/Momitsu/Foehn & Hirsch clone players.
Technika BRSS10 Blu-ray Player - £49.97
Add another item to take the total over £50.00 (e.g. mouse mat for 97p). At checkout, enter code TDX-KMAW or TDX-KG4T for £10.00 off £50.00 spend. Collect-from-store delivery is free, or standard delivery starts from £5.00. Don't forget to go through TCP/Quidco for an additional £1.31 cashback.
More information on Technika BRSS10:
Multi-region hack:
Switch on
Open tray
Press set-up on remote
Enter 9113
An additional configuration menu will appear on the left hand side of the screen that allows you to change the DVD Region to any or region free. Below that it lets you set the Blu-ray Region to A, B or C.
