technics su-x101 when does the fan kick in?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by reidy-, Jan 30, 2009.
  1. reidy-
    reidy-
    Jan 19, 2009
    49
    at what wattage does the fan come on at from what people have been saying its roughly 40% or 40watts,
    the speakers I am using are 6ohm but the amp is only rated to 8 ohm's will this cause a problem?, the fan isnt usually on, just when there is some loud heavy bass going down. I am just trying to find out how much headroom I have left.
    are there any safety cutoff's on this model i.e. a temperature based trip switch. or will it just frag itself if it gets too hot?
    also if any one has the manual or know's where I can get one for free that'd be great
