Mick The Greek
I’m after some advice,
At present I have 3 x technics Se-a1010 amplifiers which I have tri-wired to my linn majik speakers.
I have banana plugs at both ends of the cables. In order to connect them into the amplifier I had to remove a small plastic tab from the amplifier terminal so the plug can go in. I’ve had it like this for 3-4 years and never had any issues but was advised recently that I should not do this as the plug would only be connecting at the tip.
is this correct and could this cause or have caused any damage.
if this is correct what’s the best way to connect the plugs?
MTG
MTG
