Technics SC-HDV600 Subwoofer Settings
Discussion in 'Home Cinema Buying & Building' started by tjvanman, Aug 8, 2005.
  1. tjvanman
    tjvanman
    Hi, I'm new to this forum and would like to hear from anybody that can give me advice on the setting up of my TECHNICS SC-HDV600 system to get my active sub-woofer to work.
    I have had this system for nearly 2.5 years and it has been working fine, still is, but on the addition of an active sub, I cant get it to recognise that it is there when I run through the test sequence.
    Is there anyway that I can test, using a meter to see if I am getting an output signal, or with any other tool that will show if it is mt system, or my sub that is at fault.
    If I pull the cable out of the DVD, slightly I get ath sub to start bouncing all all over the place, but when I push the cable back in it doesn't do anything.
    I added the new sub, which is an Eltax Atomic 8, active sub, when I moved and also need to know the settings for the surround sound as it doesn't seem to be working too good either since I put it back together after my move and I can't remeber how it was set-up as it was quite some time ago that I did it, so any help would be most appreciated.
    TJ
