technics sc-hd560
Discussion in 'Hi-Fi Stereo Systems & Separates' started by baldbird, Sep 20, 2003.
  1. baldbird
    baldbird
    I'm looking at buying a new hi-fi, maximum £300. I'm looking at the technics as above - is it any good or does anyone have any better ideas for under £300.
    Cheers:confused:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    what are you after from it????
    CD and radio or just CD do you have any speakers at the moment????
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=44375
    add
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=205415
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=300129
    OR
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=205700
    With something like
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=301130
    on these if required.
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=101492
    Or save some money having AMP/CD/Tuner (analogue) £200 ish and get a pair of these:
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=205366
    Should give you much better sound and will give you a much higher flexibility: E.G. Plug your PC in for sound from MP3 games and movies and plug in your TV for much better TV sound!!!
    For seperates allow 10% of budget for cables but all the cables to get the units up and running should be in the boxes, get some good speaker cable and upgrade the others you go pleanty to be found on the classifeids here due to our continual need to upgrade!!!:smashin:
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Ok having seen which technics system you are looking at it is a good system for the money but i would be wary of the speakers that come with it! a future upgrade to something like Mission M72i may be worth considering.
