Technics SADX1050 question
Discussion in 'AV Receivers & Amplifiers' started by Greg Hook, Nov 25, 2001.
  1. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,866
    2
    In a secret location with Jennifer Lawrence
    +10,911
    I am currently looking to replace my current Technics receiver for a newer model. SA-DX1050.
    Looking through this months HCC I saw it advertised by Sound and Vision and it looks quite good. They state in the ad that it is THX ultra and has DTS-ES.
    I then had a look at last months HCC when this was reviewed and there is no mention at all of THX ultra or DTS-ES. Does anyone know if this receiver does have these features or have Sound and Vision made a mistake.
    Greg
  2. APPLEBITE
    APPLEBITE
    I was looking at the same reciever, and it doesn't have either of those features. I decided on the Technics DA-10 instead.
