Technical question
Discussion in 'TVs' started by Chris Hedlund, Jan 7, 2005.
  1. Chris Hedlund
    Chris Hedlund
    I was in the local superstore looking at a range of TVs, which were all playing the same music videos. The name of the track was displayed along the bottom of each screen.
    Now as the scene changed in the video (light to dark, dark to light etc) the words in the display seemed to jump about (unstable). What is going on here?
  2. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    poor power regulation-a lot of TV's do it. my Sony HQ100 doesn't though thankfully(but does have other issues!)
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    When the brightness changes in the picture, the "beam current" changes too, and this causes the HV supply (about 25,000 volts) to the CRT to vary. The variations in the HV supply cause the picture size to change slightly in sympathy with the voltage variations. You only see this effect on CRT screens.
  4. Laurel&Hardy
    Laurel&Hardy
    It will vary depending on the design though. Generally the rule of thumb is the cheaper the set the worse the effect. All the 36" CRT's I've seen are pretty good and only change slightly. My mate's cheapo (goodmans) 32" is terrible and even bends around the sky tv bar at the bottom of the screen. My 51WH is excellent in this area.
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    A huge amount depends on the design. Early colour TV's used a big valve (tube) to generate the EHT (HV), and they had another valve which regulated the EHT supply. These babies generated so much power that you could draw a spark fat enough to light a cigarette, but you had to be careful about X-Rays, though :eek: No "breathing" of the picture there, though !
    Modern designs use a much lower power transistor circuit, which generates about 8,000 volts which is "tripled up" by a diode circuit to give around 25,000 volts. Very little regulation, though. Most only rely on the graphite coating on the CRT and an inner silvering coat inside the CRT to produce a big capacitor for smoothing the EHT supply.
  6. Chris Hedlund
    Chris Hedlund
    Thanks Guys
    Could this problem heave been worsened in the shop by having all the TVs with the same picture, and therefore all changing the power supply at the same point from the same mains supply?
    Cheers Chris
  7. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,840
    Somewhere in South Yorkshire
    +5,070
    No, it's not the mains supply that's affected - that would be illegal. It's what's going on inside each set.
    One of the many ways in which CRTs do not produce the best picture.
  8. Chris Hedlund
    Chris Hedlund
    I'm no expert but bare with me while I make an observation. When I turn on my Hi-Fi amplifier it dims the house lights momentarily (and this is a new house and wiring). Why could this effect not be happening with numerous TVs on the same supply.
    Cheers Chris
  9. Laurel&Hardy
    Laurel&Hardy
    OK, when you turn on your amp it's momentarily a complete short circuit to the mains while the electromagnetic field on the transformer establishes itself. During this brief phase it will draw a lot of mains current so, for a brief moment, the lights will dim.
    This does not happen when you power up a TV because it's power supply is totally different.
  10. Chris Hedlund
    Chris Hedlund
    OK thanks for the explanation.
    Cheers Chris
