Technical info on the Sony TRV18E
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Kel, May 26, 2003.
  1. Kel
    Kel
    Can the TRV18E have DV in Enabled ? ( its one of the only models i never see listed )
    What is the spec of the mic input jack ? i.e Is it a 3 pin stereo 3.5mm ( or 2 pin mono ) or can you only use a stereo mike via the hotshoe ?
    Many thanks
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    I have checked a few companies that do DV-in enablers and your camcorder is not listed on any of their web sites. Looks like you are out of luck. Sorry :rolleyes:
    The manual to the camcorder should list the specs for the mic in jack.
    Mark.
