Technical help.
Discussion in 'AV Receivers & Amplifiers' started by alan1001, Nov 3, 2003.
  1. alan1001
    alan1001
    Hi,Iam new to the world of home cinema.I need a bit of technical advice regarding speaker connections.I have the chance to buy a system which has an ouput for a rear centre.My problem is
    running speaker wire to that position.Is there an issue with the system if I do not hook it up untill such times as I;am redecorating
    Can you set up amplifiers telllingb them what spaekers are present???
    May be stupid questions but as old proverb goes better being
    a fool for a short time than one for life.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Not stupid questions at all. :)
    Some (most?) amps allow you to specify what speakers are present beyond the standard L/R front ... you shouldn't have a problem leaving the amp unconnected, but if the amp doesn't allows speaker selection then just don't enable decoding such as DTS 6.1 which would try to generate a rear centre.
    What amp. do you have the option of getting?
  3. alan1001
    alan1001
    Thanks for the quick reply,I have an option of buying a
    Onkyo TXSR500 from a friend but started looking around and
    also looking at a sony strde695.
    Then it will be speaker time any ideas???
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    'Fraid I'm not at all qualified to recommend speakers :blush: .. suggest you try the Speakers/Subwoofer forum, lots of expertise over there. :)
    BTW, when I said don't select a decoder which generates a read-centre in the absence of said speaker, you'd not risk any damage to the amp, just you'd lose part of the soundtrack ... in case you were wondering. ;)
