Technical help with a Definitive Tech ProSub 100TL
Discussion in 'Subwoofers' started by chinesewhispers, Sep 22, 2004.
  1. chinesewhispers
    chinesewhispers
    Jul 7, 2004
    128
    Hello all
    Could do with a little advice if possible.
    We had an electrical 'moment' recently that caused a problem with lighting. It seems that it may have crossed over to the rest of the electrics for a moment.
    My amp needed resetting as a result, and I noticed no life from my sub (Definitive ProSub 100TL). I checked the fuse on the back of the sub, and it was fried, so I changed it. Now when I power on the sub, it doesn't give the satisfying 'whoomph', but the little red light does come on. Altering the volume up/down makes no difference, nor does having/not having any input to it. Power goes to the back of the unit, but it seems it may not be getting any further.
    Can anyone suggest what it may be? And what action to take?
    Many thanks in advance, I really don't have the spare cash to get a new sub yet, and my system is lost without it.
  2. chinesewhispers
    chinesewhispers
    Jul 7, 2004
    128
    In case anyone cares, I took my Sub back to the Leeds branch of Sevenoaks where I purchased it on 24th September.
    I explained the problem and they said they would send it off. The unit is 2 and a half years old.
    Got a call yesterday (6th October) to say the sub had been repaired by Definitive and returned to the store. Collected it later that day, took it home and it sounds as good (if not better) as new. Amp boards replaced under manufacturers warranty.
    So excellent work from Sevenoaks, and Definitive.
    Now I can watch those Star Wars films that people seem to be excited about :clap:
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    That is excellent service from both retailer and manufacturer who should both be commended.
  4. chinesewhispers
    chinesewhispers
    Jul 7, 2004
    128
    Indeed, that is why I thought I should post and give it a mention.
    I may even write a letter to them!
  5. juniper
    juniper
    Dec 30, 2003
    1,875
    48
    +60
    Excellent news Mark - glad to hear that you got this resolved. I'm not sure that all manufacturers (or their agents - not sure exactly how Def. Tech. operate) would have been so "generous", assuming that you were out of warranty (and possibly even if you weren't!). I hear very good things about Def. Tech in general in fact - recently demo'd their Mythos One front three, and thought they were very impressive. Not heard their subs. tho', but with great customer service they can only be onto a good thing.
