technical help please
Can somebody help me with my 42inch plasma screen, it has just started to have a problem with what look like slow activating pixals, ie. on any dark parts of the screen, you can see the sparkle for a split secound, they mainley white but also red,blue, and green. the screen is seven moths old and it is a LG42px5d. i have tried to ajust brightness levels but no luck. it does have a great pq, and have spoken to currys about it but they are not that helpful, can any one advise me please.
ijd
does thsi only happen using the onboard tuner,ie does the same happen with sky,dvd or video etc
scottyf
try looking back at your previous posts once in a while.
the problem you have is a common lg fault follow this link to your previous thread and then follow the the links i posted you
http://www.avforums.com/forums/showthread.php?t=370713
Similar threads
