Technical help: How to get Oculus Home running on DK2
Discussion in 'VR Virtual Reality Forum' started by oasismark, Jun 23, 2016.
  1. oasismark
    oasismark
    Jun 1, 2006
    13,622
    Sheffield
    +3,700
    Hello all,
    Im not very technical, so after some advice, i have a DK2 and ive had it running on a laptop. with the old DK2 SDK. I had it set up, the demo scene works, Virtual Desktop works and a few demos work.
    But i cannot get Oculus Home working at all?
    I presume it is compatible as ive seen many videos on you tube etc.
    I understand you have to remove all traces of the old DK2 stuff, then just run the new Oculus install software.
    I do this but when i run the set up it goes straight to 'Carry on in your headset' how can i stop it going direct to this?
    Also what setting should i have in the Screen options? Resolution, portrait, duplicate or extend etc.
    Sorry for the newb questions, i just want to run Oculus Home on a DK2, cant be that impossible
  2. oasismark
    oasismark
    Jun 1, 2006
    13,622
    Sheffield
    +3,700
    Ignore all this, i think its the laptop thats not up to spec..
    Actually 1 quick question:
    If the specs are lower than whats recommended, will it just not flat work at all, or will it work with low frames per second or something
