C
Concorde Rules
Hope you good people could help with a problem i'm having with this TV.
It all works perfectly apart from sometimes the sound cuts out and the on-screen UI freezes (IE volume buttons don't do anything) but picture keeps going.
Also, component doesn't work either it won't accept the signal from a Xbox 360 ?
Happens from all connections, HDMI, etc. Wiggling some of the wires at the back kinda fixes it, and i've tried re-wiring them, moving them about, making sure connections are good (continuity testing using multi-meter!).
Model is LCD32NK750HD.
How (as we got this TV free, and the parts for it range from a few £ to max of £40 for some of the boards instead of £300+ for a new TV), I was hoping someone could tell me what is wrong and how to fix it?
Many Thanks!
Many Thanks!
