techknika 105
C
chris39
hi guys i need help it wont play my war of the worlds audio cd also i need remote hack for multi region please help ive tried the hack for the 104 but it doesnt work any help would be most helpful :)
Hackeroonie
Established Member
Chris39
Try This
Open Tray
Press set up
Type 3497340 quickly. This may take a few attempts as it has to be quick. The '0' makes it multi-region.
And it'll show "Region Full" (for only a second)
Press enter
Or this one
Turn DVD Player on
Then open DVD draw from the Player(not the remote)
Then Press Up Down Up Down 3497340, you do not have to be quick
with the numbers then you should see "region full" appear for a second or two.
You may also find that you need to redo the Hack every time you need it as it does not appear to remember the Hack after Powerdown....maybe you can confirm this also.
Let the forum know which one works ...or not
Happy Hacking
Hackeroonie
G
garymv
For the 104 but you never know.
1. Press the Open button on your remote control
2. Press the Setup button on your remote control
3. Press the Volume Up button on your remote control
4. Press the Volume Down button on your remote control
5. Press the Volume Up button on your remote control
6. Press the Volume Down button on your remote control
5. Press the Right button on your remote control
6. The currently selected region should appear on the on-screen display
7. Using the Right button on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 255 for multi-region playback
8. Press the Setup button on your remote control
good luck
G
garymv
one of these
DVD-103
Multi-Region:
Turn On machine and Open tray
Enter 9, 7, 3 and 6
Screen should show 'region 2'
Enter 0
Screen should now show 'region 0'
Wait for region display to clear
Thanks to John for the information
DVD-104
Multi-Region:
Turn the player On
Open using the remote
Press Setup
Press volume buttons Up, Down, Up, Down
Press Right button
You will see a number appear in the top right hand corner of your screen, Keep pressing Right until the number 255 appears.
Press Setup to exit
Your player will now be region free
Thanks to Sonia for the information
DVD-108
Multi-Region:
Press the Open button on the front of the player
Using the Left button on your remote control, change the display to the Preference Page
Press the Down button on your remote control to highlight the Set TV Standard option
Using your remote control, press the buttons 4, 9, 5, 4 and 0, in order, one at a time NB: You may need to perform this step quicker if this doesn't work as expected
The onscreen display will display the currently selected region
Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
Power Off your player
Power On your player
DVD-230
Multi-Region:
Make sure the tray is empty
Power Off and then On again
It will now say NO DISC in the top left
Using the remote press the Right key 3 times
You are now at the Preference Page
Select the Box at the top of the screen with the Red Tick (this is to the left of the Yellow Padlock. Do Not Select the Yellow Padlock)
Now type in the code 4, 9, 5, 4 and 0
It will now show 2 as the region
Using the Down arrow move it to show 0
Now press Play and then power Off
Thanks to Paul for the information
DVD-300
Multi-Region:
Open the players tray and leave it open
Enter the Setup Menu
Select Custom (the last option on the Setup Menu)
Key in 3, 3, 3, 3 (4 numbers)
Select your code choice (Press FREE for Multi-Region)
Press Enter then Setup
Thanks to Russ for the information
DP-301
Multi-Region:
Make sure drawer is empty
Press Setup
Press Right until you on in the box with the red tick on it and press Play
Enter the code 4, 9, 5, 4 and 0
It should show as region 2
Using the arrows chose desired region (0 is multi region)
Press Play then power Off
Thanks to Mel for the information
This hacks page was last updated on Friday, February 10, 2006
you never know.
H
haydenh
Bought the Technika 1030 from Tesco yesterday, it has not got a mirror finish front panel.
I tried the hack that "garymv" mentioned for the 103, it has no effect after entering 9736 via the remote control, screen just shows the Tesco logo.
Suggestions please!!!
E
ELSHENDER
Try This
Open Tray
Press set up
Press enter
did as said. worked fine for my crapy technika dvd 105 thanks guys was looking all over for this one. as no one had said it had worked or not i thought i would do my part and mention so. again thanx now must get back to my dvd's!!! woo
Spielberg, Shyamalan, Aronofsky, Chazelle, Eddie Murphy and Mel Gibson - all the latest movies
