Techie' help needed!
Discussion in 'Satellite TV, Sky TV & FreeSat' started by rasb0, Mar 1, 2005.
  1. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    What is a Forward Path Equaliser and what does it do?? :confused:
    It's 4dB and came off the ntl coax at the back of the receiver when we decommissioned it in favour of Sky+ :D
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,281
    Manchester
    +763
    The forward path is the signal down to your NTL box ; since cable TV is 2-way there is also a return path back to NTL.
    The return path is also used by cable modems (or the one built into the NTL boxes).
    These can also be called upstream and downstream - but the latter terms are more usually used to refer to ADSL.
    The cable forward path uses QAM modulation at frequencies from about 70-850 MHz.
    The return path or return channel uses qpsk modulation in the band 21-65 MHz.
    What you have is basically a 4 dB attenuator ; hang on to it (if you are donating it, let me know and I'll PM you).
    Chris Muriel, Manchester
  3. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    Cheers for the info. I'm halfway there.
    :confused: But..... what does it actually do, just so I know for the future and can sound like I know what I'm talking about......for a change :rolleyes:
  4. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    Hi rasb0
    Me again :) I had one of these fitted originally but it later disappear when I had a box swap. AFAIK it actually reduces the strength of the incoming signal and is used where the cable run is relatively short as the boxes dont like the signals too strong either.
    Wackojacko32
  5. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,281
    Manchester
    +763
    Exactly. That is why I described it as an attenuator. A 4dB attenuator will attenuate (reduce) the signal by 4 dB.
    Chris Muriel, Manchester.
  6. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    Thanks guys :thumbsup:
    That's me off to the pub tonight to sound intelligent :lesson:
  7. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    I knew that, you knew that, but rasb0 didn't. Thats why I explained what an attenuator did :D
