Tearing My Flipping Hair Out With Xbox CAT5E Cable. PLEASE PLEASE HELP!!
Discussion in 'Xbox Forums' started by dynamic turtle, Aug 9, 2005.
  1. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    Right, before I go absolutely bananas and do something I'll regret, can someone tell me whether an xbox should be connected to a router using the "A" or "B" flavour of RJ45/CAT5E network cable?????
    I originally terminated the cable in the "A" flavour, and nothing worked. I then tried the "B" flavour (the "cross-over" variant), and it worked fine for a few days......
    Then last night, I get the "no cable connected" warning in the Xbox dashboard!! The router is also querying the connection.
    Needless to say, I swore a little bit.....
    So can someone tell me why my Xbox is being so schizophrenic?
    DT
  2. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,641
    167
    The Wheldon Road end!
    +7,846
    I just use a standard Cat 5e Patch cable (don't think it's cross over) and it works fine.
  3. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    Can you double-check, CAS? I want to be absolutely sure and get to the bottom of this!
  4. danvitale
    danvitale
    Nov 18, 2004
    2,339
    63
    By The Sea
    +114
    You should only need a cross over cable if youre directly connecting two PCs to each other.
    If youre going from a modem to your xbox or from a router to an xbox you only need a normal standard Cat 5.
  5. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    normal cable from router to xbox
    crossover from pc to xbox
  6. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,641
    167
    +7,846
    Yes the cable between my X-Box and router is a standard patch cable :smashin: .
  7. HCK
    HCK
    Oct 21, 2002
    669
    West Yorkshire
    +89
    it is most definately 100% normal cat5e cable from your router to your xbox. It could mean that you have a dodgy network cable, try another if your able.
  8. applevenus
    applevenus
    I can also confirm that you should only use a standard (non-crossover) cable with the Xbox.
    Do you notice two lights lighting up on the ethernet socket on the Xbox ?
    Can you access the DHCP table on your router to see if your Xbox is being assigned an IP address ?
  9. Tejstar
    Tejstar
    Dec 4, 2002
    22,500
    London
    +995
    I use standard patch cable from my router to xbox.
  10. nero0410
    nero0410
    Jan 5, 2004
    11,632
    southwest
    +4,395
    I use a simple crossover cable for my xbox and a patch cable with my ps2 and a crossover cable with my laptop.
    They all go into a simple £18 7 port hub, which is connected into my bt voyager 200 router.
    And everything works fine, and all at once if needed.
    tris
  11. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    OK, well I tried a standard "straight through" cat5e and it worked fine.
    Maybe it would have been better if I hadn't fixed it - I've got a bad case of "HaloHead" this morning :(
    DT
  12. applevenus
    applevenus
    'HaloHead'... is that the constant ducking & diving as you walk around the office... looking over your shoulder and throwing the occasional grenade toward your boss's office ?
    ... know the feeling...
  13. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    Lol :)
    Can anyone explain how it worked for a short period (1 session) with cross-over variant cat5e then, 'cos I'm stumped?!
    DT
  14. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    628
    +39
    Some routers have auto detect cable thing you can use either xover or patch with them. Not sure why it stopped, did you try resetting the router or maybe its because the cable is damaged.
  15. MartinH32
    MartinH32
    May 6, 2005
    1,695
    2
    Castleford
    +293
    Network card and cross over cable from B&Q for £16 all in is all you need to network the two together. Standard network cable will not work without a router.
    :smashin:
  16. nigelbb
    nigelbb
    Apr 4, 2005
    5,262
    103
    +488
    Most routers, switches & hubs nowadays auto-detect & allow you to use either straight through or crossover cables.
