Has anyone tried teaching a Harmony a new IR command recently? I've got one of the older remotes (Harmony One) and the latest software (7.8.0.0) which seems to work ok with the odd quirk on Windows 10.
When a device is missing the odd button here and there I can't get the learning to work, it goes to the right page when I select Learn IR then I scroll right to the bottom to Learn a new command, give it a name and it goes to the learning page where you plug in the remote and press the button on the original remote. It detects the button press ok and then just goes back to the Learn IR page without adding the new command.
I've tried it with a couple of remotes now and it does the same with both, can anyone test it and see if it works and what it should do after it detects the keypress?
