TEAC Reference 500 - AH500 Amplifier
Discussion in 'Hi-Fi Stereo Systems & Separates' started by pippin, Aug 23, 2004.
  1. pippin
    pippin
    I've had a problem with my AH500 amp, which has been switching on and off intermittently. It now won't switch on at all.
    I've checked the fuse just in case and it's OK.
    The rest of the system is also OK.
    Anyone had a similar problem?
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    I had a similar problem with a chord amp. Turned out to be a dodgy connection in the power circuit. Had to send it back to Chord in the end. Is your amp under warranty?
  3. pippin
    pippin
    Unfortunately the warranty is up.
    I was thinking that it sounds like a faulty power switch.
  4. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Still worth contacting TEAC. They may still be able to offer advice.
