Teac Reference 100 - faulty?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by cyberman, Nov 20, 2004.
  1. cyberman
    cyberman
    the cd tray won't open, it doesn't even try so it's not a mechanical fault, tried the reset switch to no avail.
    Is this a known fault?
    Thanks.
    Dan
    oh, and :lease: help me! :oops: , also, i have :rtfm: and it said nothing :p
  2. Flimber
    Flimber
    Sep 22, 2002
    13,360
    Yorkshire
    +4,477
    Take the top off and see if the little rubber drive belt has slipped off or broken ? Or if it's a cog involved, has it somehow slipped or become wedged by some grit or something ?
    HTH,
    Mike.
  3. cyberman
    cyberman
    Flimber, Thanks for replying.
    However, as you'll see, it's hard to see anything in there!
    When pressing the eject button, nothing happens, however, it wakes the unit from standby so i know the button works. There is no sound of anything, nothing happens, hence electrical.
    I can't see much inside....
    Anyway, i'm taking it in for repair early next week.
    Just annoys me because it's barely been used, ever.
    [​IMG]
    Cheers,
    Dan
  4. Flimber
    Flimber
    Sep 22, 2002
    13,360
    Yorkshire
    +4,477
    Are all the ribbon cables properly seated ? Might be worth carefully removing and reseating any which you can get at. Can't hurt to try, unless you're a thirteen-fingered cyclops - and there aren't too many of those on the forum, AFAIK.
    Mike.
  5. cyberman
    cyberman
    Hi Mike,
    All of the cables are secure unfortunately.
    It just seems as though the motor ain't operating....
    I've had a quote of £70+ for repair...... Goddamn.
    Dan
