Teac Legacy 700 + mission FS1
Discussion in 'Home Cinema Speakers' started by izzy01, May 8, 2003.
  1. izzy01
    izzy01
    looking to buy the above setup, anyone got any veiws on this type of match, poss alternative sugestion?
    ta
  2. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
    get the Mission FS2 (about £400), they sound much better IMO.
    They are much easier to layout around ur room (u dont need to have perfect placement).
    The fs1's look nicer than the fs2's...
    (the stands for the fs1 cost £70 !)
    for the same amount of money you could get one of those Velodynes VX10 (or similar)
    and maybe
    Kef Cresta 2's Fronts
    Kef Cresta 1's Rear
    Kef Cresta Centre
    + cables
    This setup would come up to about £400, and would probably sound better than the mission speaker packages
  3. izzy01
    izzy01
    thanks for the reply, I dont need the stands as they will be mounted on the wall on the picture rail.
    size is important I have looked at kef kht2005 but they are too buglike and noticeable.
    have you heard the missions back to back?
    i have heard that the fs1 is better for music and i will use the system for both dvd and cd
    I was also condsidering the pioneer nsdv1000 for completeness
