teac LCD and Samsung home cinema
rbartlett
chaps just bought a s/h Samsung ht-x30 home cinema system which i have connected a teac T19 l1638 LCD for kitchen use
Connected via the HDMI cable as
Two issues
1 I cannot get the Samsung to play sound from the TV and not sure which function it needs to be connected up to as it didn't work via Scart scart lead I tried either
2 is there a code Samsung samsung remote so I can do away with the teac one
tia
richard
davepuma
You will need to connect the TV to the home cinema using an audio cable that is common between the two.
a. what audio outputs does the TV have?
b. what audio inputs does the home cinema have?
As for codes, check with Samsung.
rbartlett
Sorry for the late reply I have been tied up with the Olympics
I have attached a pic of the Tv and here is the reciever
http://downloadcenter.samsung.com/content/UM/200703/20070316145717015_X30_TX35_GB.pdf
The last unit I had (Denonworked ok till it blew up) but I can get everything else except sound from the TV to play through the home cinema speakers...:-(
Any help much apreciated
Richard
davepuma
I can't make out the connections on the TV from your link as the writing is too small. Does it have analogue audio output i.e. red/white phono? I can see an analogue audio input next to the component video input but you need an output.
Does it have a digital audio/spdif output? Your home cinema has an optical input so ideally you're looking for an optical out but if it has digi-coax you could get a converter.
rbartlett
I have attached a larger picture. As I say the last unit I had was a denon and that worked via the scart lead so I'm a bit confused
Thanks again
Richard
