Teac DV H550
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by bugsterbuns, Jun 10, 2004.
  1. bugsterbuns
    bugsterbuns
    Apr 24, 2004
    170
    The Multi-region Hack For The Teac Dv H550
    Bugsterbuns
    p.s
    Tested and works a treat
  2. bugsterbuns
    bugsterbuns
    Apr 24, 2004
    170
    Multi-Region:
    · Turn On power and using the remote Open the tray
    · Push Clear, 2, 5, 8, 0 and Clear keys in order
    · Unit enters into test mode. "TESTMODE" is displayed on FL Display and some numbers are displayed on TV screen
    · Under most line on the TV screen, some numeric are displayed as "08 - XX XX XX XX AA BB CC" Region 0. Should be set so that AA = 23, BB = 23, and CC = 00
    · If the settings (AA = 25, BB = 23, CC = 02) are correct, Push Return key twice. Tray is Closed and unit exits from Test mode
    If the above settings are incorrect, correct the setting as follows:
    · Push Up or Down so that "12 XX" is Displayed on FL display
    · Press 2 and 3 in order so that "12 23" is displayed on FL Display
    · Press Select key of remote control unit
    · Push Up or Down so that "13 XX" is displayed on FL display
    · Press 2 and 3 key in order so that "13 23" is displayed on FL Display
    · Push Up or Down so that "14 XX" is displayed on FL display
    · Press 0 and 0 keys so that "14 00" is displayed on FL Display
    · Confirm "08 - XX XX XX XX 23 23 00" is displayed at under most line on the TV screen
    · Push Return key twice. Tray is closed and unit exits from Test mode.
