Tea Accident: Can a magic remote be taken apart
_Dragon_
Joined
Sep 29, 2008
Messages
2,241
Reaction score
304
Points
597
I had a message from my parents saying they spilt tea over the remote and now the on/off button on the remote doesn't work same with the number buttons, they have to use the wheel to go through the channels.
Just wondering if its possible to take apart the remote to dry it out?
I'm guessing that a new remote from LG is going to cost alot? I did a quick scan on google and found argos do a universal remote, but couldn't find any original remotes from LG.
Yes, most remotes can be taken apart and cleaned/dried out.
Check for any hidden screws in the battery compartment and under labels then carefully prise the two halves apart…there are usually hidden clips along the sides.
Start at a bottom corner and work your way up. Mobile phone tools and spatulas are handy for taking them apart.
Be careful, do not use a knife and watch your fingers.
Although a little late now, grabbing a spare non-Magic remote from the likes of eBay is worth considering. I grabbed a suitable, genuine LG remote for a tenner.
When I go round to them I will have a look to see if I can gently prise it apart thanks.
I will have a look on ebay then to see if there is any if I can't get the remote working. Thanks.
When looking for a replacement Magic remote, note that there are several flavours. The design seems to change slightly from year to year. I can't the changes causing any compatibility issues, but when LG, you never know.
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
