Tdl T-line 3 *help*
Discussion in 'Home Cinema Speakers' started by minimal_fuss, Aug 2, 2005.
Thread Status:
Not open for further replies.
  1. minimal_fuss
    minimal_fuss
    Jun 24, 2005
    240
    Norwich
    My friend has a air of TDL T-LINE 3. I know the company went bust in 1998 and richer sounds bought the name and there have since been no rpoducts.
    but i know nothing about these speakers....spec of any kind and original selling rpice + estimated value now, would be great.
  2. Timmy C
    Timmy C
    Oct 10, 2003
    5,181
    +398
  3. mad pierre
    mad pierre
    May 13, 2009
    7
    I currently have both sets of these.
    The T-line was a different speaker to the RTL 3.
    Although the sizes were similar, the construction was much more solid and the components used of a much higher quality, especially the drive units- the tweeter being the metal dome from the mega expensive reference model.
    In terms of sound, the t-lines have a much more detailed and focused sound throught the range. The base especially is much tighter and better controlled, though possibly a little too light for my taste (being used to the more punchy but less acurate rtl3's and mainly rock music)
    Noticibly more information in the upper midrange/treble and a better soundstage and 'ambience' in the t-line3.
    In terms of price, i belive the T-line3's were around £1200 at close of trading with the Rtls about half that. i recently saw some tlines go for £350 on ebay, whereas the RTL3s can be found between £70-100 (earlier type) and £110-150 for later (with integral plinth) facelift and SE models.
    Peter
    PS. Used with Sony CDP555es and Mission 777 power amp.
  4. Bald Monkey
    Bald Monkey
    Aug 11, 2006
    7,122
    +1,084
    :eek: This thread is over 4 years old!!!
    :lease:
    Closing... :confused:
Thread Status:
