nuggstein
Hi all,
I've been browsing this forums for years...since the Xbox 360 days.
Anyways, my current setup:
- TCL 65-S405 4K HDR Roku TV
- Vizio SB4051-C0 5.1 Surround Sound/soundbar system (this is not a 4K or HDR soundbar, but I don't use it for video output, except for my cable box). There is only one HDMI-IN, one HDMI-OUT, and one Optical-IN.
- ARC/CEC is enabled for control over my soundbar. ARC must be enabled for CEC to work.
- I strictly use HDMI ARC for control over my soundbar with the television remote. Due to handshake issues with the TV and soundbar (no sound when TV turns on sometimes), I use optical audio out from the TV to the sound bar for audio. This TV successfully passes through 5.1/DTS audio, according to Rtings.com, and is proven to be working with my original Xbox One.
- I have the original Xbox One configured @ 1080p, + HDMI Bitstream Out + DTS. Dolby Digital does NOT work properly due to middle channel/rear channels not working properly. DTS works beautifully (orange light on sound bar). Don't forget, video/audio is being transmitted via HDMI from the Xbox One, to the television, then out of optical from the television to the soundbar. However, ARC is enabled as well.
The issue:
I need to configure the Xbox One X for 4K + HDR + HDMI Bitstream Out + DTS.
I just got the new Xbox One X. I set it up the same way as the other Xbox, except this time I enabled 4K + HDR. Both of those work, however, when configuring the audio settings, I am unable to select anything other than HDMI Stereo. The Xbox throws me an EDID error (0x80bd0009), saying my receiver is not compatible or something along those lines.
Oddly enough, if I enable Optical audio on the Xbox, set that to Bitstream out, and then select Dolby Digital, I am then able to change HDMI audio to Bitstream out, and turn off Optical audio. Dolby Digital will stay selected, and I will see my soundbar's light turn white, which means Dolby Digital is enabled.
As I stated before, Dolby Digital does not work properly, and I need DTS. If I then select DTS after doing the above, it fails, and gives me the same error.
The TCL television is properly configured for HDMI 2.0 and DTS.
I am not sure how to fix this, except by getting an optical audio switch, and connecting the optical-out of the TV, and the optical-out of the Xbox One X to the soundbar directly, then enabling Optical on the Xbox. This is an annoyance, as it now adds an additional piece of hardware to an already working automatic network.
I am using a certified 18 Gbps high speed HDMI cable for maximum throughput, and 4K + HDR abilities.
After doing other research, I have already tried changing the output mode on the Xbox from Auto to HDMI, but then I cannot select 4K or HDR.
I also tried buying a $20 HDMI splitter that has some odd EDID switches on it. I played with it, but got even worse results.
I know they make EDID emulators, but those seems to be far and few between, and don't allow 4K + HDR, or more than 2 channel audio.
Any thoughts/ideas/comments would be greatly appreciated!
Thank you!
The issue:
Thank you!
