Taz, how much to build this
Discussion in 'Home Cinema Building DIY' started by nathan_silly, Jun 15, 2003.
  1. nathan_silly
    nathan_silly
    Taz, I need a MDF cabinet to fit CD's, and it must be strong enough to hold my Kef 200 centre on top (11kg)
    How much will this cost?
    Vertical sides are shown in skin colour, horinzontal in blue (although leave it unfinshed, I'll paint it black myself)
    oh the external depth must be 170mm, and have a back wall to add strength (plus the + to add strength to the top shelf)
    Nathan
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Well an 8'x4' shett of MDF is 10.98 at B&Q and they will cut the sizes you need for 50p a cut i think (3 free). Make cheaper than the postage mate have some DIY fun its great!!!
    Just dont let the missus watch!!!
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Reply from Taz, as he is having postage problems:
    Sorry mate, Flat out with CAD stuff, have no time on my hands. but should be a piece of cake to build.
    Far cheaper for you to build than for me to post, let alone charge you labour and materials.
    Taz.
  4. nathan_silly
    nathan_silly
    bump for Taz.
