Targa Home Cinema Projector £ 699
Discussion in 'Projectors, Screens & Video Processors' started by bullyx, Dec 2, 2004.
  1. bullyx
    bullyx
    Nov 23, 2004
    26
    Glasgow
    Is this any good ??, on offer at Lidl
    REGIONAL OFFER - Only available from stores in the Midlands, Norfolk and Lincolnshire, London and the South East / South West of England (except Gloucestershire and Hereford)
    This is a sophisticated single chip DLP TM based projector for the commercial or residential entertainment user. It enables you to project precise images up to 200 inches across (measured diagonally) from your PC or Macintosh computer (desktop or notebook), VCR, DVD player, camera or a laser disc player.
    DMD type: Texas Instruments Single Chip 1 x 0.55" DMD chip
    Colour Reproduction: 16.7 million colours simultaneously
    Projection bulb: 220W NSH 150 NEH
    Resolution: 854 x 480 wide VGA (dpi)
    Lens: 1.18 x zoom
    Image size: 76cm to 760cm
    Projection ratio: 1.6:1
    Projection modes: front, rear and ceiling
    Lamp lifespan: 2000 hours (ECO mode: 3000 hours)
    Key Stone adjustable: automatically, + or - 15°
    Audio: 1 x 1 Watt Monaural
    TV and Video-S compatibility: VGA, SVGA, XGA, SXGA
    CE compatibility: PAL/SECAM/NTSC 4.43; PAL M, PAL N, PAL 60 PAL/NTSC
    Sound level: 28 dB (in ECO mode at 800 ANSI lumen, 26 dB)
    Power consumption: 204 Watts (7.0W Standby)
    Size (mm): 190W x 115 H x 345 D including protrusions
    Weight: 2.6kg (projector)
    What's in the box?
    Projector with lens cap
    Remote control with Lithium battery (CR2025)
    Power cable 4.5m
    RGB signal cable
    Composite video cable
    S-Video cable
    Audio cable (RCA)
    Scart adapters (Video to Scart with audio L/R & RGB to Scart with audio L/R)
    Soft carrying case
    Band (use for bundling cables)
    User's manual & quick guide
    Warranty card
    Features you'll enjoy:
    Low-level operation noise
    New Colour Management system
    New lens shift feature
    An extremely crisp accurate image scaling technology
    Wall colour adjustment
    Brightness - 1000 ANSI lumen
    Contrast ratio 1000:1
    3 Year Guarantee
    Price per item
    £ 699. *
  2. AMc
    AMc
    Nov 20, 2000
    5,824
    Near Norwich
    +2,343
  3. Elephant Man
    Elephant Man
    Jul 15, 2000
    295
    England
    +4
    Lidl is selling the projector again, does anyone own one? Is it any good.
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    Price goalposts have moved considerably even since December. Check out the Toshiba ET1 which you can get for around £400, and it's native widescreen which the Targa doesn't seem to be.
    And also check out the Benq 5120 for a bit more, or the Epson TW10H.
    ...PJ
