Targa DP-5100x
V
vic11
Would appreciate help on the following please.
I am using the DP-5100x dvd Player and am very happy with it so far. However I do have a question regarding DivX films that I would appreciate an answer for. I have two DivX films which play on the computer without any problems.
Film 1 will play in the DP-5100x without any problems but Film 2 plays but has a sound sync problem whereby the sound doesn't match the picture and gets progresively worse as the film plays.
The only difference between the two films is the frame rate. For film 1 it is 25 frames per second (this one plays ok) and for film 2 it is 23 frames per second. Would this be the reason for the sync problem?
Thank you
Vic11
aligamer
Yeah sounds like it, any footage under 25fps will probably be outta sync n jumpy/stuttery playback on a divx dvd player- just remove the bitstreams with mpeg4modifer and all shud be good! :)
