Tar Gat
happyhiker
Help !
I used to have a 4:3 crt and when ever I watched Stargate on Skyone I lost alot of the picture cos its in widescreen. I really noticed it when the adverts came on and the title screen said TAR GAT instead of STAR GATE.
This is one of the reasons I thought I need widescreen, and therefore I want Plasma.
So I've now got a PW6 via JS RGB>VGA converter and I'm watching Startgate, the adverts come on and Shock :eek: It still says TAR GAT!
Whats going on? I've tried Switching the Screen through 16:9,4:3 and JUST(what is JUST btw ?) and all of them give TAG GAT.
I know you need SCART to use Auto, but I'd have thought one of the three options whould make the screen fit. Anyone any ideas ?
S
Skunky Cubes
I leave my CRT TV on 16:9 most of the time. This is OK for widescreen programs but 4:3 does get stretched. There is a mix of aspects currently been braodcast which is a pain. Auto aspect doesn't work and if it does it's not quick enough (and I don't use scart). I also have a zoom funtion which clips off edges of the picture. Good luck. Sorry I cannot be more specific
cyberbob69
Have you changed your sky settings?
If not go into Services on your sky remote and then picture setup and you will see. 4:3, change it too 16:9 I think that should sort it out... :thumbsup:
happyhiker
Ahhh, No I haven't changed any sky settings. I'll check it out tonight thanks.
