Tap water...
Discussion in 'LCD & LED LCD TVs Forum' started by .hack, Sep 16, 2007.
Tags:
  1. .hack
    .hack
    Jun 24, 2006
    716
    Walsall
    +96
    Yup, I used tap water to clean my new TX32LXD70. I now have lots of annoying stains all over the screen. :suicide:
    What would be the best method to remove the stains the tap water has given my screen?
  2. nitro23456
    nitro23456
    Jul 30, 2007
    293
    Resident Panasonic LXD70 Expert
    +15
    proper anti static LCD/TFT screen cleaner.
  3. benrp
    benrp
    Aug 22, 2006
    264
    28
    +41
    Best way to clean it is to use a proper tft/lcd screen cleaning solution.
    Or make your own solution using half isopropyl alcohol and half distilled water.
    Remember, always use a lint free cloth or you'll end up with lots of tiny fibers everywhere.
  4. .hack
    .hack
    Jun 24, 2006
    716
    Walsall
    +96
    Microfibre cloth [check]
    Distilled water [check]
    Do you happen to know any stores that sell isopropyl cheap? Will pick up from maplins otherwise.
  5. Tinderbox (UK)
    Tinderbox (UK)
    Feb 5, 2007
    594
    28
    England
    +36
    you can buy isopropyl at most chemists.
    you can buy, white microfiber cloths at tesco a 3pack for £0.89
    regards
    John.
  6. .hack
    .hack
    Jun 24, 2006
    716
    Walsall
    +96
    Looked just about everywhere for distilled water, can't find it. :/
    Is deionized water the same; is it safe to clean the screen with? That was all I could find.
  7. SDMDAM
    SDMDAM
    Jun 2, 2007
    1,600
    117
    +847
    Where can these be bought then?
  8. benrp
    benrp
    Aug 22, 2006
    264
    28
    +41
    Deionized water will be fine
  9. benrp
    benrp
    Aug 22, 2006
    264
    28
    +41
    Lots of places - like Amazon, Empire Direct. Just Google tft screen cleaner.
  10. nwgarratt
    nwgarratt
    May 5, 2002
    27,785
    +3,190
    Just search for TFT cleaner or LCD cleaner. They are alcohol free as alcohol is used in many sprays and can be lethal to LCD screens.
    I recently got the 3 microfibre cloth pack from Tescos and they will do fine. I am not using any sprays on my screen.
