Tannoy vs. Monitor Audio
Discussion in 'Home Cinema Speakers' started by OldGitEd, Jul 5, 2004.
  1. OldGitEd
    OldGitEd
    Jun 27, 2004
    I have narrowed my search for some bookshelf speakers down to the Tannoy MX2 and Monitor Audio B2's.
    My choice of SUB is still being made, but I will probably settle for either a MS 309, xls 200 or mj pro 50.
    My amp is a Yam 440.
    I need your informed opinions.
    I am also not having any luck finding the mx2's in any other finnish but dark oak. Anyone know where to find others?
    Will a Tannoy Mx C as a centre speaker be suitable for my choice?
    I live in a small Welsh town so demo's are not an option.
    Bokdrol
  2. bobbypunk
    bobbypunk
    Monitor audios are a much better speaker IMHO and in that case best centre would be the Bronze centre!
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    If you choose the Tannoy Mx2 as fronts then also take the matching center (MxC).
    Can't comment on the MA Bronze and how they compare to each other but I used to have the Mercury series (forerunner of the MX) and was quite pleased with them.
    However they could not cope with my amp's power (Yamaha DSP-A1) so later I upgraded to the now discontinued Monitor Audio PCM series which I still own and love. :)
  4. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    I love the both companies' products. Some of Tannoy's high-end stuff is breathtaking. MA's budget stuff looks a better design-wise though!
  5. OldGitEd
    OldGitEd
    Jun 27, 2004
    Thanks R & DT
    I have been searching my mouse into exhaustion to find a pair of Tannoys in any other colour than dark oak. No luck yet.
    I do fancy the MA's though, but with the centre and a Sub I am stretching it a little.
    Any online shop that you can recommend?
  6. MagicBoy
    MagicBoy
    Sep 19, 2003
    308
    +21
    I believe the MX-M range are going discontinued, replaced by the new Fusion range. Not seen any reviews on the Fusions yet.
    I'm very happy with my MX-M setup which I've had for 4 months. I ordered from www.hifistore.co.uk.
