Tannoy TS10 Sub - One Month Later!
Discussion in 'Subwoofers' started by William YZF-R1, Feb 7, 2009.
  1. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    Well I have had my TS10 for about a month now.
    Overall it does a good job and bass is well defined and "tight" compared to my previous cheaper sub.
    The only downside (and I was asked about this on here recently) is that its not heavy enough! On a couple of occasions (Independance Day DVD & Disco remix music) when asked to reverberate really low it literally vibrates on the floor very noisily - the metal spikes on the concrete floor thru carpet.
    A liitle annoying nevertheless and possibly easy cured by placing something heavy on top. At the moment I have masked the shortcoming by removing the metal spikes and it sits on the carpet instead.
  2. GMC79
    GMC79
    Apr 1, 2006
    10,647
    Glasgow
    +3,178
    U could try putting something under the spikes to stop it reaching the concrete, say like pennys or 5p's or somthing. May work and is something i would try before putting something ugly on top.
  3. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    Thanks, I will try that, but suspect the jackhammer effect is because its physically not heavy enough for the otherwise excellent job it does.
    I emailed Tannoy this morning just to inform them, and ask if they are aware of this minor problem.
  4. GMC79
    GMC79
    Apr 1, 2006
    10,647
    Glasgow
    +3,178
    ok yeah mayb ur right just looked up spec. 9.5kgs makes it a Kg lighter than my small MJ.
    And i could have swore u ordered the TS12 when i seen the thread on xbox.com forums. :confused:
  5. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    Your right, but after waiting 3 weeks and with no firm delivery date, I cancelled and went cheaper. Too cheap I might add, so a week later I cut my losses and purchased the less costly (compared to TS12) TS10.
    Overall I spent what a TS12 cost but ended up with a TS10 plus a cheap heavier subwoofer that is now a relatively expensive ornament:(
  6. SoOPersOniC
    SoOPersOniC
    You should use the rubber feet that came with it. The granite worktop savers are also a good platform to sit it on.
  7. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    I believe the jackhammer effect is caused by placing it on a firm surface. There were no rubber feet supplied, just the plastic conical feet and spikes whch screw into them.
    I watched Independance Day again with the TS10 minus spikes on the carpet. It was fine as presumably the carpet absorbed the shocks/jackhammer effect but at the end of the day I think it was built too light.
  8. SoOPersOniC
    SoOPersOniC
    I would agree that it is too light, my TS-12 is too light really.
    But they are otherwise very good subwoofers, I used the rubber feet and have a granite worktop saver. This has cured my problems.
    I would have an SVS sb12 if it wernt for the fact that my TS-12 cost me £200 and upgrading would be pointless (ie pretty much just the same as SVS sb12 just a lighter enclosure).
  9. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    Thanks, I like the TS10 as well but I wouldn't like to use it on a smooth surface like a laminate floor - God knows where it would wander off to during a decent film.:devil:
    I might try to source some rubber feet with recesses in the centre, and bolt them to the feet where the spikes go.
