Tannoy TS-8
Discussion in 'Subwoofers' started by Hudson, Sep 1, 2005.
  1. Hudson
    Hudson
    Jan 7, 2005
    259
    +4
    Anybody had experiance of this little sub ?? i have a room measuring about 11ft by 13ft (dedicated AV), I have an all Tannoy 5.0 system with front floorstanders (635) and matching centre and rears. I though a sub would be a good thing to add around about now. Any opinions.
  2. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    898
    28
    London
    +25
    I don't think with subs it's as necessary or useful to stick with one manufacturer, although having said that, I bought an tannoy arena sub to go with my tannoys. Actually, it's more correct to say I bought an arena sub to go with the decor of the living room.
    It's a fairly small room, so you'd probably be advised to look at all the usual small sub suspects BK XLS200, etc.. The TS8 is supposed to be not too bad, either, I guess.
  3. garyerr
    garyerr
    I have a TS8 and it sounds OK to me . I had to get a smaller sub to replace my old REL Q50 because I needed the sub sited in a different part of the room. I also needed a new sub that played the higher frequencies because of the size of my main AV speakers. Does it sound as good as my REL ? , it is difficult to say. It has a different frequency range, obviously doesn’t go as low, but I haven’t noticed much difference and the REL has gone now so I can’t compare.
    I don’t have all speakers in exactly the best place , but does anyone who doesn’t have a custom made room , and just uses their living room for watching movies, it’s a compromise.
  4. snow
    snow
    Jun 8, 2005
    25
    3
    christchurch
    +3
    hi there hudson,i have a ts10 being the next size up from yours and have found it an enjoyable sub indeed,it is matched to my mission V63 mains and centre with mission bipole rears . I replaced my old energy sub with this model just because of size mainly plus it was getting on a bit but foundthe tannoy matched the older sub very well,not maybe quite as much slam but not too bad, i found the tannoy is a very good musical sub keeps good rhythm with the rest of my set up.Hope this helps.PS have found that sealed subs tend to keep a better and faster beat than ported in my opinion.Paul:
