Quantcast
Tannoy TFX 5.1 Speakers - Upgrade?
dougan
I have just bought a Denon AVR-X2600 AV amp, my present speakers are Tannoy TFX 5.1.
I am looking to upgrade these, the only criteria is they must be of similar size.
The Q Acoustics 7000i Plus has caught my eye, would these be much of an upgrade over the Tannoy's?
andysnowboard
Hey pal, did you get anywhere with this? I have the same tannoy speakers but looking at changing the front to the q acoustic 3000 range
Romster1
HI Dougan do you know what db and frequency range of the TFX surrounds? im considering getting some but cant find the tech specs on them.
dougan
Just looked in the manual, and it says 140Hz - 78Hz. 85db .
Wired in my QAcoustics 7000i's yesterday, so my TFX's will be surplus to requirements!
Davekale86
The Q Acoustics will blow them out of the water I had some of the sfx 5.1 when I was starting out they was okayyyyy, now have some Wharfedale DX1 SE Speakers that are really good for the price
Davekale86
Is it just surround speakers your looking for if so highly recommend the Cambridge audio minx M12
Romster1
cheers I have seen them the reviews were a bit indifferent. im just looking for some which will be easy to drive not for my AV amp but for the wireless rears for my soundbar which I currently have a pair of Tannoy 628 surrounds hooked up to the rear transceiver unit for the bar instead of the tiny Samsung supplied ones idea being that i will take the tannoys up to my bedroom to hook up to my av amp which ive got large Tannoy fronts and centre hooked up to already.
Davekale86
Don't be put off by the reviews they are really good think they are 39 quid each and the brackets are 14 well easy to install too get em you won't be disappointed
Romster1
cheers ill keep an eye out. they've been a few on ebay recently and I know some peopleare using them for atmos heights too.
Romster1
currently at £49 at RS. I note thsat its nt a 2way speaker so does the lack of a tweeter effect the dynamism and subtle rear effects?
Davekale86
No they are very good for the price get them off the Cambridge audio website they are £39 each and you can choose black or white plus with the difference in price you could get the swivel brackets too, if I was going to get another setup them are the speakers if would use for a full 5.1 with one of the centre speakers from them.
Davekale86
what's the high frequency response and sound like on the minx 12 seeing as it doesnt havea tweeter?
Tech specs are there, as for the sound for the price you probably won't get a better speaker, they do sound really good and like yourself I was looking at Atmos speakers for ages and finally settled on them, having a Atmos setup really does open up the front sound stage, its a shame you can't demo them however they are really good
Davekale86
I wouldn't worry about the fact of the tweeter, like I said they are really good for the price unless you spend more and again the frequency response, just get them haha
Romster1
finally got them hereafter the courier was taking the P do you know what the mounting screw size is is it an M6 ?
Davekale86
Fir what? Have you got the brackets too? If you have the brackets have all the parts apart from wall plugs and screws to put on the wall
Similar threads
Trending threads
Latest News
Micro LED TV alternative to modular design on the way?
  • By Andy Bassett
  • Published
Musical Fidelity announces M8xi integrated amp
  • By Andy Bassett
  • Published
Sky announces price rises for UK
  • By Andy Bassett
  • Published
LG Display OLED panel production below forecasts
  • By Andy Bassett
  • Published
Panasonic launches SC-HTB600 and SC-HTB400 soundbars
  • By Andy Bassett
  • Published
