Tannoy SFX Sub
Discussion in 'Subwoofers' started by Haizum74, Jan 30, 2009.
  1. Haizum74
    Haizum74
    Dec 29, 2008
    693
    York
    +43
    I am having a few teething problems with getting my sub set up as the kit I have had before has been all in one systems and has dealt with the sub by itself.
    Its connected up to an Onkyo 606 with the SFX Speakers too and I just need some advice regarding the Hz info. I currently have the fronts, centre and rears at 120Hz and the sub the same. Ideally should the sub and speakers be at the same setting like that?
    I have tried reading up on Hz and apart from the one time where I ended up on the Car Rental website I am rather perplexed.
    When playing DVDs I am getting bass coming through the floor but it doesnt seem to have the 'boom' I expected. I understand it shouldnt be too overpowering but it seems a bit 'wet' (ironic really I as I was testing it with Master and Commander)
  2. ResidentDeagle
    ResidentDeagle
    Dec 18, 2008
    1,838
    Nottingham
    +62
    set the sub to 60 or 80 hz you`ll get a smoother sound from the sub setting it to 120 hz i find makes it very boomy and make it sound like a cheap logitech set or something.
    let me know what you think of the results i think youll be impressed.
    60hz is probs better.
    your speakers should be 80 hz.
  3. ResidentDeagle
    ResidentDeagle
    Dec 18, 2008
    1,838
    Nottingham
    +62
    i garantee you will notice a difference as the sub is meant to be set low.. and it`ll sound more natural and smoother.
  4. Gixer1970
    Gixer1970
    Nov 15, 2005
    1,115
    Kent (UK)
    +114
    How are you getting on with this ? I have the 607 and the following readings from auto setup with (check signature) speakers.
    Front 40Hz
    Centre 100Hz
    Surround 120Hz
    LPF of LFE 100z
    Speaker Impedance 6 ohms
    I dont think I am getting the best form this set up and as the original post I feel the sub could be better.
    many thanks.
