Tannoy Revolution R2 Will They Match?
Discussion in 'Home Cinema Speakers' started by abnett26247, Jan 7, 2005.
  1. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    IVe bought new a pair of tannoy revolutions R2 s to be the fronts with my also new also new and also unpacked R2 revolution centre both v big. ive been told the two pair of also new unopened tannoy MX 2 s i also bought for the rears 7/1 are less than a perfect match to the big different model range on the front revolutions??Is that correct ,? because they where all ment to be used as surround for music , ie i should have bought tannoys revolution R2 s also for the back, insted of the tannoy smaller MX 2 s, Im not sure what tob do sell the lot, e bay ect or try to buy new or second hand tannoy Revolution R2 s for the rear maybe using just one pair of the MX 2 s to make it 7/1 in the corners . any advice please or does any one know where i can purchase anouther set in BLACK ONLY Tannoy R2 s ? Seems tannoy have no more Revolution R2 s i had the very last pair this week, many thanks for advice or even if you know of any seconhand R2 s youve seen for sale .This is not an add its a cry for help.
  2. russraff
    russraff
    Aug 1, 2000
    2,415
    Newcastle
    +64
    The obvious choice for rears would have been the R1's.The rears do make a diff, especially when listening to multichannel music.
    Russell
  3. roman-r
    roman-r
    Jun 11, 2004
    6,340
    83
    London - Stoke Newington N16
    +183
    http://www.petertyson.co.uk should have R2s and owning a pair myself I highly recommend them ;)
    Don't sell them, just break them in over a couple of all night plays from your radio and enjoy - it's easy to get to absorbed by what other people say ;)
  4. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    YES LIKE TO KEEP THEM BUT WHERE CAN I FIND ANOUTHER PAIR FOR THE REARS AS YOU SY YHAT WOULD BE IDEAL< THEN JUST SELL THE 2 PAIR OF MX " S < > GOT TO FIND SOME R2 s ?????????????????????????????
  5. 337GUS
    337GUS
    Nov 1, 2000
    753
    NE Scotland
    +38
  6. roman-r
    roman-r
    Jun 11, 2004
    6,340
    83
    +183
    If you go to the Peter Tysen link I originally posted and click 'Deals and Offers' then 'HiFi Speakers' you will find R2s :)
    Assume they are still in stock
  7. abnett26247
    abnett26247
    Jan 2, 2005
    227
    16
    THANKS ONLY RED NOT BLACK STILL SEARCHING
