Tannoy mxsub10 any good?
Discussion in 'Subwoofers' started by duncanvdlinden, Dec 29, 2002.
  1. duncanvdlinden
    duncanvdlinden
    I've a ht setup with 5 tannoy mx-m speakers.
    But i haven't enough bass in music.
    Now i want to buy a subwoofer not only for HT but also for
    stereo music.
    I think the mxsub10 is a good choice because the rest of my speakers are from the same speaker range.
    But many peaple said me the tannoy mx-sub haven't enough power. and the bass going not so deep.
    I've also the the rel quakeII on my wishlist.
    wich one is a better choice for me, Tannoy mxsub or Rel QII?
    my setup:
    -Marantz sr4200 receiver
    -Tannoy mx2-m front.
    -Tannoy mx1-m rear
    -Tannoy mxc-m center
    my room is 3x4 m
  2. Guest
    I had one and its pretty poor, and suffered from a really audible subsonic humming noise (bad PSU isolation?) that drove me potty once I noticed it.
    I went instead for a REL Q50 and couldn't be happier.
  3. duncanvdlinden
    duncanvdlinden
    Is this the only reason why you don't like the tannoy sub?
    maybe you've got a wrong one with humming noise.
    it's not normal for a sub :)
  4. Guest
    I went through THREE Tannoy subs. before getting a refund! (had 2 MXs and also the Saturn S15)
    I think if you do a search Tannoy subs are pretty well known to be noisy, although apparently cutting the earth lead on the cable can help.
    I'm a Tannoy fan too (if you look in my sig.) but I'd really recommend you get a sub. from a specialise.
  5. mudan
    mudan
    Nov 26, 2001
    226
    Solihull
    +18
    My MxSub 10 performs well with no humming noise at all. Looks like they may have revamped the design.
  6. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    my old MSub10 had the same humming problem with the stock mains lead but disappeared with a decent one (proof indeed that mains cables work)
    if it were my money though- Mordaunt Short 309 no questions asked!!
    on the subject of Tannoy subs tho
    anyone seen that tasty Dimension TD12 Tannoy sub? 80cm tall and 'only' £4k!!
