Tannoy mxsub 10 or yamaha sw90 sub
Discussion in 'Subwoofers' started by mixalot, Mar 13, 2001.
  1. mixalot
    mixalot
    I have just bought a set of tannoy speakers (av2 set) and need a sub to go with them. I had the tannoy sub on order for £170.00 but they will take one month or more to get. I really want the sub straight away so i am thinking of getting the yamaha but i haven't seen any reviews on it. Iwant to spend a max of about £190.00 to £200.00
  2. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,122
    Leicester
    +51
    Try and get a Paradigm PDR-10 from Richer Sounds,£150,awsome,you won't regret it,it's got rave reviews and from this Forum aswell.
