tannoy mx10 sub any views?
Discussion in 'Subwoofers' started by fama, Feb 7, 2002.
  1. fama
    fama
    Jan 28, 2002
    142
    does anyone use or have views onthis
    also interms of cost as i see it available for well under £200
  2. ilkand
    ilkand
    Feb 9, 2002
    404
    +3
    I have a Tannoy msub10, which I think is very similar (not positive on this one though). It is a small subwoofer but can produce quite a lot of nice bass. I like it as I use it, at line-level for the LFE channel using the filter on my sony amp, but at speaker level it is poor as it does not have very good filtering of its own and lets a lot of higher frequencies through. It was good value I think - most subwoofers are too expensive for me.
  3. mudan
    mudan
    Nov 26, 2001
    227
    Solihull
    +19
    I've just ordered the Tannoy Mx-10sub to use with my Tannoy 609II main /623 center/Mission 760i surrounds and Sony DB1080 set up.
    I know that the Tannoy is a budget sub and I could do a lot better by spending more however this should suit my needs for now and am happy to upgrade it at a later date if necessary.
    It would be interesting to hear from people who already have this sub.
    Thanks,
    Dav.
