Tannoy MR Rears
Discussion in 'Home Cinema Speakers' started by PaulBoy, Nov 9, 2000.
  1. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    I was looking for some decent rears to replace my existing not so good ones and initially looked at the MX1 which is very highly rated - Unfortunately they are too big for my room and I cant find any reviews of the MR's which are about the same size as my existing ones ... Has anyone got them ? Are they any good ? Are there any reviews I can look at ? Thanx ... Paul
    "Hi my names Paul and I'm a dvdaholic ..."
  2. lukas
    lukas
    Hi Paulboy,
    for some reviews look at the surround speaker section of www.audioreview.com.
    I own 2 m1's. I believe the Mr's are twice the costs of the M1, but they are far more audiophile. Its sound is more 'spacier', because of the more expensive wood they used for the cabinets.
    Hope this helps you!
  3. bigalroz
    bigalroz
    Nov 21, 2000
    53
    Stirling,Scotland
    Guys,
    I think Lukas is getting confused. Tannoy MRs are actually a bit smaller than M1s and usually sell for around £70 I think. Check out the tannoy web site www.tannoy.com for more info.
    couldn't think of anything interesting or witty that's why my signature is so sh***y
  4. wwwebber
    wwwebber
    Jul 17, 2000
    212
    28
    Nottingham, England
    +60
    I have the Tannoy MR's. They are indeed smaller than the M1's (about half the size). I needed smaller rear speakers due to space and have found that these little gems are just great.
