tannoy m1=r1
Discussion in 'Home Cinema Speakers' started by mongo, Jul 21, 2001.
  1. mongo
    mongo
    wot is the differance to the tannoy m1 and the tannoy r1 ???
    me i can tell no difference only the big price differance!!!!!!!!!11
    get back
    thanks
  2. mongo
    mongo
    LOOKING AT THE SPECS ON THE TANNOY SITE THE ONLY DIFFERANCE IS THEY ARE BI-WIRE
    ALSO WOT DO YOU MEAN VINEL WRAPPING??
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The M1 is replaced by the MX1 now, it's a budget speaker with vinyl wrapping.
    The R1 is real wood or real wood finish, can't remember but it makes a difference in the price as you see.
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Please do me a favour and switch off your CAPS.
    This is considered shouting and therefore rude. Thanks!
    Vinyl wrapping is a cheap way of coating the speaker in different colors.
    On the Mercury series the wrapping was actually pretty poor (in terms of craftmanship).
    I think that has been improved for the Mx series (still vinly wrapping though).
    The Revolution series is either "wrapped" in real wood (a very thin layer of wood glued onto the MDF) or made of real wood (i.e. solid wood).
    Craftmanship is not that good either, just saw a few pairs at an exhibition and the edges showed quite some flaws.
    You get what you pay for .... ;)
  5. mongo
    mongo
    ok mon this better
    wot rears do you recommend then????????
    other than the mx2s i was looking at ( could of got them for £ 89 also i do not see rears to be so immportant to the frounts i have jamo cornet 75 6ohm fronts and they are better for home cine than for music i no tryed
    get back
    thanks
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    For the rears I would either take matching speakers, if not because too expensive some M(x)1 will certainly do.
    Or consider di/bipoles, like Mission 77DS.
  7. tan1415
    tan1415
    Were you considering the M1's as your rears?
    Well they'll be excellent ones.
    The new MX1 is not as good as the old M1.
    Teh old M1s is good enough as stereo speakers, while the Mx1 is made speacially for being rears.
  8. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Tan, I think you confuse the Mx1 with the MR, the MR are made specifically as rear speakers and are very small.
    I still rekon to either match the rears to the front (R1 in this case?) or go for the Mx1.
  9. mongo
    mongo
    wot about the tannoy mx2 speaker they are bi-wire also how mutch are the mission ones??? :rolleyes: :p ;)
