Question Tannoy HTS101XP - replace centre?
Discussion in 'What Speakers Should I Buy?' started by dunamis, Nov 27, 2017.
    1. dunamis
      dunamis
      Mar 8, 2005
      200
      +5
      Hi folks.
      I'm just replacing my rather old KEF Eggs 2005 set with Tannoy HTS101 XP speakers.
      As you probably know, all the satellites in the Tannoy set are the same - including the front centre.
      Do you think it's worth replacing the centre with something else and if so - any suggestions?
      (Keep in mind it only cost me £350 for the whole set so I wouldn't want to spend any more than £150 on a replacement centre)
      Thanks! :)
      RG
    2. gibbsy
      gibbsy
      May 17, 2007
      14,058
      3
      Cwm Cynon, De Cymru
      +7,897
      It's always best practice to keep the front three from the same model range to preserve timbre across the front sound stage. If you really think you need a better centre then best stick to Tannoy.
